which sensors are compatible with Labview?
Hey guys ...
plz help me
THNAKS IN ADVANCE
Message 1 of 18
(6,076 Views)
There are too many to list.
What type of sensor are you looking for?
Can you describe what you are trying to do?
Message 2 of 18
(6,068 Views)
we need wireless color sensor ..
to distigwish between 2 colors ....
Message 3 of 18
(6,040 Views)
Most color sensors output a frequency directly proportional to the light intensity, the frequency is commonly a square wave. You can read the frequency of a square wave, depending on the DAQ you are using in LabVIEW.
Alan
Message 4 of 18
(6,022 Views)
check out
www.testcoachcorp.com
I'm not sure that they have wireless products, but you may be able to attach it to a wireless device / interface.
As Alan mentionned these can be used with DAQmx.
Message 5 of 18
(6,008 Views)
Or if you are into Microcontrollers this would be a very good solution,
http://www.parallax.com/dl/docs/prod/acc/tcs230-db_doc.pdf
 It is specifically designed for the Basic Stamp, but there is enough information to adapt it to , say a PIC, or my choice (always) ATMEL.
Alan
Message 6 of 18
(6,003 Views)
Thanks a lot for your coopertion
I'll explain what I want to do ..
I want to build Safety Dam System using WSNs ..
I will make the dam as a simulation .
The water inside the dam is represented using blue color , when it exceed predetermined threshold value then the color is changed to red.
The sensor is monitoring the dam . When the dam color is blue , the gate is still closed.
But when the dam color becomes red then the sensor reads the data and send an instruction to open the gate .
Note , the red water decreases when the gate opened until it reaches the threshold value then the water color is changed to blue and the gate is closed.
Help me PLZ ,,,,, I need your help .....
Message 7 of 18
(5,955 Views)
Pick any colour sensor who will output an analog signal.  Use the simples DAQ card with that to communicate with your software.
e.g. : http://www.everlight.com/index.php?option=com_k2&view=item&id=267:single-color-sensor-analog&Itemid=...
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
Message 8 of 18
(5,952 Views)
Migrant-bird,
Is this ALL a simulation? Do you really want to connect real world sensors to a real world DAQ? Is this a School Project?
Alan
Message 9 of 18
(5,944 Views)
ABCPrograms
does the sensors in EVERLIGHT run wirelessly and are they copatible with LabVIEW ??
ajmartin
just I want to build a simulated dam using JAVA ..
the  water is moved from bottom to top .. it starts with blue color then when it exceeds the threshold , the color is changed to red ..
put the sensor beside the screen and when it senses the red color then it reads the data and the action is " open the gate "
Message 10 of 18
(5,930 Views)
