which table object can be edited during run time by user?
No wonder. An alternate  in LV7.1 is to use "table" object though it would look different from others.
Sigh. Smiley Indifferent
Clement
Message 11 of 13
(744 Views)
Hi astroboy,
If you want to edit the cells programmatically, I've attached a LabVIEW 7.1 example that takes in the column number, row number, and text to change the cell, and changes the cell on a button click. You may or may not want to use this. I hope it helps!
Message 12 of 13
(732 Views)
I  am using Labview 7.0. Is there any way for run-time editing of the muticolumn listbox.
----Vishnu
Message 13 of 13
(620 Views)
