while loop in a while loop
Hi all,
         I am trying to write a program with a while loop within another while loop. When I run the vi both while loops  run but then only the inner while loop seems to update, I adjust controls and they have no effect on the indicators.
Thanks..
Message 1 of 9
(4,823 Views)
The outer while loop will not update until the inner while loop finishes, at which point the whole dance will start again
Message 2 of 9
(4,822 Views)
You need to familiarize with the concept of dataflow programming. Run your VI in "execution highligthing" mode while watching the diagram and you'll get a better feeling on how things work. 🙂
If both loops need to run in parallel, place them next to each other without data dependency.
Can you explain what you are trying to do? 🙂
Message 3 of 9
(4,818 Views)
So is it a bad idea to have one within the other if I was them to run simultaniously? Should I put the two whileloops side by side? I have attached the block diagram
Message 4 of 9
(4,817 Views)
It all depends what your program should do There are scenarios where stacked loops are appropriate. Typically, one loop is sufficient if you want to run most of the code at 500ms interval, but some parts at 2000ms interval. Just place the 2000ms parts in a case structure and activate it evey 4th iteration of the big loop, for example. 🙂
Please attach the real VI instead of an image. It is much easier to see what you have.
Message 5 of 9
(4,813 Views)
Hi there,
I am trying to send a boolean value from one loop to another to stop the loop also am trying to send a value form one loop to another.
Thanks.
Message 6 of 9
(4,804 Views)
Hi
If you want to send values between two loops (running in parallel), do not wire them up, instead create indicators for the values that u want to pass and use their local variable in the loop where you want to read/receive them.
Hope it helps!
Message 7 of 9
(4,746 Views)
Hi sparrow...,
do you know dctoni?
Message 8 of 9
(4,733 Views)
GerdW wrote:
Hi sparrow...,
do you know dctoni?
Nice answer, GerdW! Smiley Very Happy
- Partha ( CLD until Oct 2027 🙂 )
Message 9 of 9
(4,678 Views)
