while loop "not worknig" without the option " activate animation" on
Hello
I'm working on Labview 8.6 with FPGA module
in my VI i have a loop working with a device on a RS232 link, a while loop updates the status of the device on the front panel
Alone this loop works fine
My issue is that when the rest of the program runs this loop is kind of in a standby mode (all the program work exept the status of the devices is not updated)
BUT if i turn on the animation (the yellow light to see the dots running the cables) my while loop works and the status is again updated
if i turn off the animation the loop returns "silent"
any ideas?
Thx
(3,035 Views)
Accepted by topic author Damiien
Do you have any while loops running without any wait statements in them?  It sounds like symptoms you would have if you had a "hungry loop".  Basically a loop that is running so fast eating up 100% of the CPU resources that it doesn't yield time to the processor to do things like display updates.
(3,032 Views)
i just checked the CPU and ideed labview is using 100% while my VI is running.
should i insert wait box in all my while loops ?
(another loop has a clock showing on the front panel and is not slowed or stop with the problematic loop)
Message Edité par Damiien le 03-11-2010 09:37 AM
(3,027 Views)
hungry loop spotted (bad loooop bad ! )^^ thx a lot !Smiley Very Happy
(3,012 Views)
