while loop
Hi krispiekr…,
i don´t understand your code. How many parallel loops do you have now? Can you upload more code, so we can help to clean up and show you a way without local variables?
Mike
Message 11 of 16
(997 Views)
Hi krispiekream,
you may use much less locals when you would use shift registers:
When changing TempDwell and OtherLoop to control and indicator, respectively, you would get rid of two more locals... And I just notice: I forgot to delete the TempCycle local!
Message Edited by GerdW on 04-29-2008 08:53 PM
Message 12 of 16
(989 Views)
i got the temp problem solved..but i have a lot to learn about not using local variables..
i have this vi that is working..but its filled with sequences and local variables. i dont want mess with a working code so i didnt bother cleaning it up...
can you see my codes and see what i can clean up..
Krispiekream
Message 13 of 16
(984 Views)
that is some nice programming...
i'll try to clean my program to look like that..
Krispiekream
Message 14 of 16
(982 Views)
Here's another quick draft using autoindexing. It may need to be tweaked a bit. I am not sure why you use indicators as controls and vice versa.
I don't undestand a lot of your logic and it is probably wrong. This is a somewhat literal refactoring. 😉
Message Edited by altenbach on 04-29-2008 12:17 PM
Message 15 of 16
(972 Views)
Since "refactoring" (the process of cleaing up the code) takes a long time while this should not change the functionality of the code, it is recommended to implement the code in a proper way from start.....So i recommend you to look into examples shipped with LV or you can download from NI website just to see what possibilities are out there to reduce the usage of variables and sequencestructures 😉
Norbert
Norbert
Expert: Geometry
Message 16 of 16
(939 Views)
