while loop
Hi Guys,
I would like to know if there is any possibility to send data out of a whileloop? in my attached snapshot I want to read out the number of iteration(loop count) when the program execute, but I can only see the result of last iteration that is normal while usinge a whileloop but is there any other possibility to see data toggling out of the while loop?
Beni.
(3,793 Views)
There are many ways you can use Globals (not recomended), local variables, property nodes, LV2 style globals, ques. look at the help for using each one. also search for some tutorials on how to use them.
Joe.
"NOTHING IS EVER EASY"
(3,774 Views)
I don't get you, anyway, I am asking that question because I just want to make a subvia of the application and of course some indicators shows the last iteration value which is normal because of the while loop, I am surching for a way to read out data for each iteration out of the while loop.
thx
(3,749 Views)
I would recommend that you look at a queue implementation.  You can enqueue the data inside your subvi and then dequeue the data outside the subvi.  You could also use notifiers, but be aware that there is the potential for lost data if not programmed properly.  There are shipping examples with LabVIEW which show the use of each of these.
You may also use LV2 style globals (also called functional globals).  LV2 globals have distinct advantages over standard globals with regard to race conditions in the program.  LV2 globals use a single iteration loop with a shift register in which to store the data.  There is a significant amount of information on this forum about the use of LV2 globals in your programming.
Message Edited by John Rich on 07-26-2005 09:13 AM
(3,748 Views)
If I understand what you mean... You have a subvi with a whileloop inside. you connected the Iteration counter to an indicator
So, in your top vi you get only the last iteration count. That is completely normal. The top vi gets the value of the indicator after
the subvi completed his job.
If you want the iteration counter to change while the loop is runing, you should use a reference to the indicator on your top vi and
use a property node to change its value.
Dai
LV 7.1 - WIN XP - RT - FP
(3,734 Views)
Here is a vi that uses a couple of examples for you to try.
Joe.
(3,726 Views)
thx for support,
it is working fine!
(3,698 Views)
