while reading a file how to put a delay between each reading
While reading a text file how to generate a delay between each reading?
(2,907 Views)
check this out:  http://forums.ni.com/t5/LabVIEW/read-and-average-n-data-from-text-file/m-p/1189799
If you inculde in the solution VI the "Wait (ms)" from the Timing library I think it will do what you want.
Krivan
(2,898 Views)
There does not appear to be any reason at all to read the file line by line. The example noted above is not really what you want to use either. Read the entire file at once and pass the array to the for loop, taking advantage of it's auto-inexing feature. Get rid of all that split and dynamic data silliness. I assume that you want to output a single data point at a time.
The ost above is correct that just need a wait function inside your loop.
(2,883 Views)
