while taking out rms accelerations all sampling sizes not processed
i have measured acceleration using accelerometers at a sampling rate of 5000,but i am unable to produce rms values ,showing the errors as follows.some one who got out the solution refer me t
(2,307 Views)
Can you attach the code where you think you are acquiring at that sample rate. What hardware are you using? Some DAQ devices have only certain rates that they support and will coerce a rate you specify.
(2,291 Views)
