who can tell me how to reference a specifed VI included in a LLB?
I want to use the function of "open VI reference" to get a refum to a VI inculded in a LLB file,but the "I/O path control" only accept the LLB file instead of the specified VI .who can give me a suggestion?
(2,774 Views)
All you need to do is add the vi file name to the LLB pathname in the I/O path control.
eg c:\My Project\My LabVIEW.llb and the VI is MyVI.vi
the resultant pathname is c:\My Project\My LabVIEW.llb\MyVI.vi.
You could use the Build Path function in the File I/O palette.
Hope this helps.
Regards
Ray Farmer
Regards
Ray Farmer
(2,774 Views)
Under 6i,
Right click on the Path Control.
Select browse options.
Under Selection Mode, select existing files (use LLB's).
This should allow you to select a VI from a LLB use the Path Control.
(2,774 Views)
