wht does lv7 help files for DAQmx lockup?
I am trying to obtain help for the DAQmx vis in LV7 and the help files "hang", take for ever to load and sometimes lockup LabVIEW. Also, when they do load, the pull down selector does not work properly and causes the help file to lockup. Is there a fix for this problem?
(2,458 Views)
If you are currently running NI-DAQ 7.0 or 7.1, download NI-DAQ 7.1. This new installation will include new help documentation that will overwrite the existing files on your machine which may be corrupted. Here is a link to the NI-DAQ 7.1 download page: http://digital.ni.com/softlib.nsf/websearch/C1F802E457EA042586256DD00001B0C9?opendocument&node=132060_US
Bill B.
(2,458 Views)
