04-06-2016 03:28 AM
I am using a labview program to drive the 6602 timer into generate 5MHz pulse. The output is not able to reach the frequency. what could be the reason ? The NI DAQmx driver timebase will set automatically to 80 MHz based on the request. Please sort out
04-11-2016 09:03 AM
Can you post your code?
