why can't I see the menu bar of a vi in a subpanel
As the title says, why can't I see the run-time menu of the VI I inserted into a sunpanel?
Doug Ferguson
Message 1 of 10
(4,043 Views)
This is by design (and also stated in the LabVIEW Help). The subpanel only displays the front panel of the VI. The run-time menu is not considered part of the front panel.
Message 2 of 10
(4,031 Views)
... However, if you really need access to a menubar, you can pass a reference to the calling VI's menu to the VI in the subpanel and manipulate it from there (create/delete menus, handle selections, etc...). Just be sure the plugin VI cleans up after itself when it closes.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 10
(3,990 Views)
I read the Help and understand it is on purpose, however why?
I have functionality in the Run-Time menu that I want the user to access. I ended up hacking the same functionality with a tab control. It doesn't look as nice but it gets the job done.
Doug Ferguson
Message 4 of 10
(3,895 Views)
The why is really rather simple: Logically a window can only have one menubar. So if you want a subVI to interact with a menubar that is the one it has to use and the way to get to it is through the menu reference from the top-level VI. In use this is actually a very clean and systematic way of implementing the functionality.
Mike...
LabVIEW Champion
Message 5 of 10
(3,889 Views)
I know how to interact with menu items in multiple VIs programmically, however how do I display the subVI's RTM when it is placed in the subpanel so that the user can select the RTM items from the subVI?
Message Edited by doug@southerndaqsolutions.com on 01-05-2009 03:04 PM
Doug Ferguson
Message 6 of 10
(3,881 Views)
Mike already gave you the answer in reply #3: pass a reference for the calling VI's menubar to the subVI, and have the subVI modify the parent VI's menubar.
Message 7 of 10
(3,875 Views)
As explained you can't and LabVIEW does not allow this for a good reason. It is accepted knowledge in UI design and considered bad UI behaviour to have a menu other than a context popup or anywhere else than under the title bar.
LabVIEW adheres to that and most probably would have to jump through a few hops too to actually make this possible at all.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 8 of 10
(3,871 Views)
No he didn't answer why, he just offered an alternate solution. However modifying the parent menubar wouldn't work in my case.
But thanks, this is all I was looking for "It is accepted knowledge in UI design and considered bad UI behaviour to have a menu other than a context popup or anywhere else than under the title bar."
Message Edited by doug@southerndaqsolutions.com on 01-05-2009 06:19 PM
Doug Ferguson
Message 9 of 10
(3,858 Views)
Not to make too much of it, but I did tell you why: A subpanel can't have a menubar of its own because (to quote myself), "...Logically a window can only have one menubar...". Maybe not as classy as Rolf's statement - but then Rolf is a classier guy.
Mike...
LabVIEW Champion
Message 10 of 10
(3,837 Views)
