why do I get VISA code error -1073807202 when trying to connect PXI-2565?
I got error code -1703807202 (a code library required by VISA could not be found) every time when I first started up the computer and used "Initialize with topology" to connect my channels.  This error would go away if I start MAX and open up devices and interfaces, then re-run the same task.  How do I get rid of the error?  Thanks.
Message 1 of 8
(4,269 Views)
Hey Pal,
This error means VISA is not installed properly.  I would download the most recent version of VISA that is compatible with your system, install said version and then see if that fixes the issue.
-John Sullivan
Problem Solver
Message 2 of 8
(4,241 Views)
I have Labview 7.0, VISA 4.0 and Window 2000.  I thought this is a working configuration  Should I try to install VISA 4.4.1?  Is it possible that it's a Window driver initialization problem?  Thanks for the help.
Message 3 of 8
(4,239 Views)
Hey Pal,
I would try repairing the install first.  To do this, open Add/Remove Programs and then open the 'National Instruments Software' tab.  The repair utility is located inside of this tab.  If the repair does not work, I'd recommend uninstalling VISA, restarting, and then Reinstalling
-John Sullivan
Problem Solver
Message 4 of 8
(4,231 Views)
I ran into another scenario where Old Visa library wouldn't work and give me an error.  Is ni-VISA Labview-version specific like DAQmx and niFgen?  For example, would the latest niVISA for Window XP work with older version of Labview?
SB
Message 5 of 8
(4,178 Views)
Hey Pal,
You are correct about NI-VISA having requirements for LabVIEW.  The latest version of NI-VISA won't work properly with LabVIEW 7.0.  You can see the supported versions in the readme of the driver.  For example, NI-VISA 4.4.1 is compatible with the following versions of LabVIEW:  8.6/8.5/8.2/7.1.1.
What error are you running into?
Caleb W
Message 6 of 8
(4,160 Views)
I ran into error -1703807202 when trying to control my power supply.  Let me try a different driver and I'll update you with the result.  Thanks
SB
Message 7 of 8
(4,154 Views)
Accepted by topic author sangbui_palpro
My bad, GPIB driver wasn't installed
Message 8 of 8
(4,140 Views)
