why do i get error 7 at new file when trying to run the calibration?
We have installed the DAQ software/drivers and then installed the Labview calibration program all according to the user manual.  As soon as we try to start the calibration after clicking "OK" when prompted to insert the standard unit, I get a message saying "Error 7 occured at New File".  How do I change the file path manually?
(2,702 Views)
You will need to provide more information. What "LabVIEW calibration program"? What are you trying to calibrate?
(2,700 Views)
We are using LabView 8.5 and we are trying to calibrate UV Light Meters.
(2,688 Views)
Ummm... well, that's a little more information, but it doesn't help to shed any real light. You still have not explained what LabVIEW program you're running. Is this something you wrote? Is this something you got from somewhere? Did it come with the light meters? Can you post the code?
(2,660 Views)
