why do i get error code -2147024891?
I am trying to us LabVIEW6.0 to open Excel and then load a given sheet. I copied and then modified the code from a Print Excel VI. Anyway, the code worked for a while and now it does not. my error block says that "access is denied. error in ###.vi" the number -2147024891 is in the error number block. Any ideas. I need to open Excel and then view the file on the screen.
thanks,
wheeler
(11,609 Views)
I don't think the error code 2147024891(long) 80070005(hex) has anything to do with LabVIEW. The error code description is "General access denied error." I'll suggest you check anything that has to do with access restriction with the excel file and on your system.
(11,609 Views)
This is definitely an access problem. I also got this error when trying to write data to a Datsocket server on another machine. It turns out I needed to give CREATE priveleges to my machine (or everyhost) using the Datasocket Server Manager.
To fix access problems when writing to Excel, here are some reccomendations:
-Make sure excel isn't already open. Sometimes it might be open, but hidden. Check the NT Task list to make sure excel.exe isn't running.
-Check dcomcnfg priviliges and security. Type dcomcnfg at the command prompt and check the secutiry setting for Excel.
http://www.medicollector.com
(11,609 Views)
FYI:
This "error" I had with Datasockest also manifested itself in other strange ways. The problem (as I explained above) was that I did not give CREATE privileges to remote users. On some machines, I would get the error code 1101 every other time I tried to write to the remote DSTP Server. The first write would be successful, but the second would give error 1101... and so on.
(11,609 Views)
