Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
why do i get "error 1 occured at Config Data Registry.vi(get data) invalid object 0" while running my application
hameed
Member
02-25-2003
09:23 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
OS Ver : WinNT 4.0
Labview Ver : 6.1
0
Kudos
Message
1
of 2
(3,096 Views)
Reply
Re: why do i get "error 1 occured at Config Data Registry.vi(get data) invalid object 0" while running my application
Jeremy Braden
Active Participant
02-26-2003
11:35 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Do you have the run time engine installed? If so, you might consider reinstalling it.
Can you get any LV executable to run? Attached is an executable that runs on my XP box with LV 6.1.
LV_61_build_into_an.exe 55 KB
0
Kudos
Message
2
of 2
(3,096 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
