why does Xcontrol cannot read global variable?
In the block diagram of Facade.vi of Xcontrol, I read a gloable variable which is updated by another vi periodically, but the returned value in Xcontrol never change.
I changed the global variable as a shared varialbe, it works properly. So what's the different between global variable and shared variable in Xcontrol?
LabVIEW 8.20程序设计从入门到精通已经出版,敬请关注!
欢迎访问LabVIEW学习乐园: http://labviewstudy.blog.edu.cn
(3,779 Views)
up
帖子被ztyaner11在03-26-2006 07:16 PM时编辑过了
(3,762 Views)
I have only done a little work with XControls, and nothing with Shared Variables, so really this is just a guess.  XControls are "running" even in design mode.  Shared Variables can be available at design-time because they are based on an external source (perhaps an external program that is running somewhere).  Global variables are only able to be read/written in run mode.
Global Variables and Shared Variables are certainly completely different in how they operate and in what they can do.
(3,746 Views)
Yes, there does be some different between SV and Global variable, but I hope both of them can be read in Xcontrol.
(3,715 Views)
up
(3,683 Views)
