05-09-2017 02:48 AM - edited 05-09-2017 02:51 AM
Hi
I tried to set up the PXIe 5170r card with simple FPGA program ( a loop just with a counter), after compilation of the program i saw this simple program take 50% of total Slice, 34% LUT, 27% Block RAM , even though i just used a numeric constant with an adder in a single cycle loop.
what's wrong??!!
thanks for your help
05-09-2017
03:04 AM
- last edited on
01-02-2025
06:46 PM
by
Content Cleaner
First and foremost: Why is this a concern?
While i no FPGA expert, you have to keep in mind several facts:
I do recommend that you benchmark a use case which fits your worst case (read: most functionality) usage of the FPGA. If it does not fit, you can start optimizing FPGA code.
You might also be interested in this FPGA guide.
05-09-2017 03:24 AM
5170r is equipped with a kintex7 FPGA that has 57000 slice as total resource. it's not acceptable that a simple counter utilize about 50% slice.
05-09-2017 07:23 AM
I am with you on this and am in no way defending LabVIEW FPGA in this case. Admittedly I am a fan of the tool. Here is what I know:
1. There are non-diagram elements such as PXIe and FAM interfacing that get compiled into your design no matter how much or how little. As an exercise try compiling an empty VI and observe the utilization.
2. The FPGA compile tool (Xilinx) will "try harder" the more your design fills up. That is, try putting two or even three times he logic and I bet it will fit. There are technical reasons why this is non-linear. See https://electronics.stackexchange.com/questions/183214/nonlinear-increase-in-logic-utilization-for-f... and http://forums.ni.com/t5/forums/v3_1/forumtopicpage/board-id/170/thread-id/141325
