why does my front panel print reverse colors?
I am using the pareto chart vi in the SPC toolkit. My chart appears correct on the front panel, but when it is printed the colors are reversed. I've tried printing on various printers, but all have the same result.
(2,800 Views)
If you are using LabVIEW 6.0, installing the 6.0.2 update may solve this problem. Follow the link below:
http://digital.ni.com/softlib.nsf/current?OpenView&Start=1&Count=500&Expand=16#16
(2,800 Views)
The solution suggested doesn't work. I have the same problem with LV 5.1.1, 6.0.2 and, finally with LV 6.1
(2,800 Views)
