why don't close front panel when the vi stop?
I call (from main3.vi) to a vi (ALpha.vi) to send data. When I stop it, the front panel doesn't close. Why?
Thank you.
Win XP / LV 7.1
(3,263 Views)
Hi vicens,
this comes from your creative use of vis server capabilities.Smiley Wink
You should only use one place to open/&close frontpanels... Or really force to close the FP!
Edited: changed attachment...
Message Edited by GerdW on 10-15-2007 02:20 PM
(3,240 Views)
Run the Alpha.vi once seperately & then it closes smoothly there afterwards. I dont know why!Smiley Surprised
But closing LV & again running the Main VI results in the same problem again.
I also ran in LV 7.1.
- Partha ( CLD until Oct 2027 🙂 )
(3,234 Views)
Remove the globals & give latching action to the booleans, thats it. Smiley Wink
(3,229 Views)
Thank you GerdW & Partha
Possibly the problem is in the global variable. Or who executes first.
Using latch action the subvi doesn't update each X time. The solution of GerdW seems more suitable.
Thanks both.
Vicen
(3,217 Views)
