why i am getting wrong signals
i am acquiring dc signals of range 0-10 volts via two input channels. i am acquiring signal of -10 volt on one channel and that of +10 volt on the second. these are very well plotted on the waveform chart. but when i disconnect one of these (say -10 volt), the disconnected signal shifts to the other signal i.e. +10 volt on the waveform chart. now the two signals show the same value. what may be the reason for that.
please solve my problem..
(2,946 Views)
What in fact you are saying is that you cannot detect a loose connection. It's an impedance problem.
When the conection get loose the input pick's up voltage signals of high-impedance values (neighbouring signals, noise or supply voltages).
An ancient solution for this solution is tying this signal with a resitor to your analog ground (the ground signal of your analog inputs). The resistor-value will depend on the output impedance of your analog sources. You could start with 100K and see if your connected measured signal drops/rises.
Detecting loose connections is one of the reasons in industrial wiring one uses 4-20mA signals, where 0 mA means a broken wire.
(2,946 Views)
thank you sir for your reply
i have got my answer
(2,946 Views)
