why i'm reciving this error ? Can any body help me ?
First you need to make sure that there is no problem in application. Generally in some OS they protect the file from writing. Hence what you do create one file in local drive D and run your application and write there. If this works then its confirmed whether its a problem of permission only.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 13
(347 Views)
And how to tell my application right to that file in D drive ???
Message 12 of 13
(346 Views)
You can give some fixe path to write to file palette.Place one MDF file there and through UDL file make sure you are able to verify connection
--Ranjeet
Message 13 of 13
(325 Views)
