why installer dosn't work?
Hello
I made a program that work correctly. i want use it in another computer, without install labview program. result, I used an installer, but when I make an installer, it dosn't work at all. actually, after run my exe file of installer, I cant find anything in computer to click on and see the program. Can you help me?
I attach my process to make an installer.
Best Regads
(3,191 Views)
Start by making an executable.  Use that as your source code.
(3,172 Views)
Thank you natasftw
may you explain more? do you mean I use application (exe) like attached picture, and I add it, to files of installer that I make them in previous step?
Best Regards
(3,165 Views)
Accepted by topic author behzad1
Yes, first you need to build an application, then an installer for the application.
(3,137 Views)
