why is IMAQdx property node not sending/receiving? Please take a look!
Hi!
Im trying to control FPS but with no result. Whats wrong with this code?
thanks!
(2,787 Views)
Please see this related thread http://forums.ni.com/t5/LabVIEW/IMAQdr-Property-Node/m-p/1642950/highlight/false#M590168
Matt
NI Community Team
(2,769 Views)
Hi, Not sure if you've already solved this...your code wont refresh b/c your slide is outside the while loop. this will only work when you initialize the first time.
(2,545 Views)
