why is it not Connect ?
(3,468 Views)
Hey,
what datatypes are in your cluster?
The Cluster to array function converts a cluster of elements of the same data type to a 1D array of elements of the same data type.
CMW
(3,461 Views)
If your cluster is all booleans, then it should work just fine.  What exactly are you trying to do here?
(3,421 Views)
maybe is better to post a pic of front panel of the cluster to let us know what type of data types are you using in your cluster.
Regards
(3,391 Views)
your cluster most likely contains data types other than boolean
(3,383 Views)
