11-17-2008 09:38 PM
11-18-2008 01:03 AM
You must register an automation server on each machine, this is done by one of three ways:
1. During the setup by the setup program
2. Registering by using the command line command regsvr32
3. Selfregistering by starting the automation server once
Be aware you must have administration rights for registering an automation server.
11-18-2008 08:17 PM
11-19-2008 02:20 AM
11-20-2008 01:13 AM
So, should I install CVI? Actually I do not install CVI individually. I thought the CVI has been installed when I am installing TestStand, is that right?
11-20-2008 01:14 AM
