10-30-2008 11:46 PM
why some Vi in LabVIEW Functions panel are not in PDA Functions panel?
such as "MT Generate System Parameters.vi".......can not run on the PDA window and say:"MT Generate System Parameters.vi":subVI is not executable.
10-31-2008 12:22 AM
The function you mentioned is not part of LabVIEW, but is part of the Modulation toolkit.
I am not expert here, but the datasheet of the modulation toolkit does not mention pda support from what I can tell.
10-31-2008 12:37 AM
Thanks for your reply.But now the problem is how can I convert this and use on PDA?
10-31-2008 03:11 AM
10-31-2008 03:15 AM
WenBin wrote:
up
could you please explain in bit more detail
10-31-2008 11:32 AM
mathan wrote:
WenBin wrote:
up
Looks like a lame attempt to "bump" the thread. 😞
Adding a (nearly) empty message places the thread back on top of the list, in the false assumption that this would generate more replies.
Well, he's partially correct, because it added the last three posts (which of course have nothing to do with the problem at hand), but it did not increase the "real" answers.
Bumping a thread is disruptive and generally a bad idea, because it adds a lot of noise to the forum. Imagine everybody would do it! There would be so much elbowing for the top spot that all substance would be lost in the chatter.
In the NI forums, bumping a thread is very counterproductive, because blue contributions (from NI) will typically (and hopefully!) wait until the thread is idle for a while.
Overall, it is a bad idea! 😮
10-31-2008 07:21 PM
11-04-2008 12:25 AM
