12-21-2007 10:49 AM
12-21-2007 11:02 AM
You should really use the error clusters! if you wire the error clusters through and strop your loop on error you can find out if a daq error is causing your problems. There might be a buffer overrun or read timeout. Sometimes when turning on or off an external timebase during a acquisition causes a high frequency bounce which acts like a very high freqency clock input. I would start with error handling and see if your daq task ends and why.
Paul
12-21-2007 11:22 AM
12-21-2007 11:40 AM
newest update about my recent test.
if i don't physically disconnect signal but turning the nob on my signal generator (the one for sampling clock) to change the frequency, the counter works well during these frequency change.
So I wonder what's the difference on the signal the DAQ sees between I turn the nob and disconnect the wires? The only thing I could figure out is high-freq noise when you disconnect wire. But will this cause counter stop working?
Feilong
12-26-2007 12:00 PM
