why there is a red cross?
I'm a new learner of labview.I did a VI which has a function of cumulatiive.But there is always a red cross when I connectiong wire.Could you help me ?Thank you !
---1110340050  MJD
Message 1 of 8
(4,366 Views)
You can't connect an array to a scalar indicator. Clicking the run arrow gives you a description of the error.
Message 2 of 8
(4,362 Views)
You can also hover over the wire with Context Help (Ctrl-H) turned on.
Message 3 of 8
(4,358 Views)
p.s. Your code makes no sense. Why add the iteration count with zero?
Message 4 of 8
(4,349 Views)
This will get you started.  You have a lot more reading to do than just that, though.
Bill
CLD
(Mid-Level minion.)
Message 5 of 8
(4,343 Views)
the function of  this code is the cumulative of N which can be changed to your desired number
Message 6 of 8
(4,330 Views)
Hi there,
I guess you need to understand about the For Loop and the auto-indexing tunnel.
Here's the link: https://www.ni.com/docs/en-US/bundle/labview/page/processing-individual-elements-in-an-array-or-a-co...
But as billko suggested, try learning LabVIEW on that link that he posted, before going to this link.
-Ee Lim-
See that button on the left side of this post...
If you feel my post is helpful, all you need is just (at most) 2 seconds to click that button, to show your appreciation. Thank you~~
Message 7 of 8
(4,288 Views)
You should right-click on your output tunnel and select 'Replace with Shift Register' from the menu:
This changes the cursor. Use this to click on your input tunnel:
This should then give you the answer you need:
Message 8 of 8
(4,229 Views)
