why won't LabVIEW window display properly when using remote desktop connection
LabVIEW window doesn't display properly when using a remote desktop connection to view the screen of a remote computer running LabVIEW.
Yes, both computers are running WinXPpro.
And yes, every other application I have ever tried (which is quite a few) on works fine.
(3,163 Views)
I've used Remote Desktop on various computers running XP pro and 98 and from PocketPCs running windows CE 2002 and 2003 and I had no problems. I see LabVIEW fine, and I see LV EXEs fine, in full screen, in a windows - no problems.
What do you mean by "doesn't display properly"?
___________________
Try to take over the world!
(3,153 Views)
are you experiencing problem with menus? if so, then you need to disable either "abridged menu" or "hot menu" in the option, I forgot which one though.
-Joe
(3,144 Views)
