wie kann ich einbinden ".so"datei mit labview program unter linux,,details
wie kann ich einbinden ein ".so"dateivon ein C program,,mit Labview in meine program,unter linux läuft labview,,und die möglichkeit das ich configurieren die Calllibrary function node,,,details bitte
(2,478 Views)
Hello Ing_Samergalal
If i understand you correctly, you are looking for more informations about "using external code in LabView".
There is a large PDF document about this issue available at this Link:
http://digital.ni.com/manuals.nsf/websearch/8D930295FFBF9F7686256D2C00624728
and some additional Links about this toppic:
http://zone.ni.com/reference/en-XX/help/371361B-01/TOC30.htm
In general informations such as tutorials and exampels on this toppic may be found in the NI Developer Zone:
http://zone.ni.com/devzone/cda/main
(2,455 Views)
hello wetzer
Thanks for Ur replying and trying to help me,,,but my problemis that imtryind to connectivity two programms together under linux my labview is also for linux,,the first programmis writen under C programm and the other is writenbei LV,,,the problemis nowhowto call the library from the C programm to open it with LV,,í´ve ready have the library from this C programm ,(.so)....i want to communicate this Files with LV...
i wish if u can help me more,,
THANKS
(2,449 Views)
