wiimote IR data rate problem
On the following link, Joe got wiimote ir data acquisition drop from 100 hz down to around 20 hz in few minutes. I am running into same problem. Does anyone know why?
 Thank you in advance.
Z.
quoted Joe's here:
I've been capturing IR data from multiple wiimotes using Wiimotelib 1.7 (as a .NET assembly) and have been getting progressively slower reads from the Wiimote.  This happens using both a polling- and event-based approach.  The rates can be sustained at ~100Hz for a few minutes but will drop as far as 10-20Hz. This is on LabView 8.5.  I've tried 2 different bluetooth adapters and 2 different bluetooth stacks, so I doubt that is the issue. Has anyone seen this behavior or offer suggestions?  I've attached a polling example.  Thanks.
-Joe
 http://forums.ni.com/ni/board/message?board.id=170&thread.id=249428&view=by_date_ascending&page=9
(3,019 Views)
I would try running this community example:  http://decibel.ni.com/content/docs/DOC-1353 . If you notice the same behavior with the ir data acquisition rate, please post a comment on the example page. You should have an NI employee getting back to you on it.
Vivek Nath
Machine Vision
(2,970 Views)
