wiimote
I want to establish a communication between LabView and Wiimote. After getting the address and the channel via the Bluetooth Discover.vi, I use the simple bluetooth clien.vi to read data from the wiimote, but I get the following error:
Error 56 occurred at Bluetooth Open Connection in Simple Bluetooth Client.vi
Possible reason(s):
LabVIEW:  The network operation exceeded the user-specified or system time limit.
(3,449 Views)
there is a wiimote toolkit on this forum just search wiimote
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,446 Views)
Can it be done without it, only with simple LabView VIs? I have something specific in mind and I want to do this:
Press any button on the Wiimote, and use the data that represents this particular button to command an RCX-driven LEGO robot.
(3,440 Views)
are you useing the NXT or the old RCX 2.0? if you are using the NXT there is also a toolkit for it and yes you can create your own toolkit but it is better not to reinvent the wheel as I am pretty sure the wiimote toolkit does recognize all the buttons on the wiimote and if you want the bool information you can simple use that toolkit in combination with the NXT toolkit to control your robot. search around the LabVIEW forum and you will find some articals that may help you.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(3,434 Views)
Yes, that's what I'm doing now!!! I'm using the old RCX and "Robolab for Labview".
(3,429 Views)
