wilcoxon sign ranked test
Here is my quick test implementation.  I recycle the Rank Transformation.vi from the NI version and then sum the ranks of the 0 elements to make the correction for multiple ties.  p-value.vi performs a linear interpolation on two consecutive integer p-values.  You could add a check to only interpolate for non-integer values if you like.  pk(i).vi uses native recursion to solve the recurrence relation for a p-value.  The lookup table used by the NI version is probably faster, I just wanted a quick ground-up implementation.
Message 11 of 11
(336 Views)
