will labview 4.1 for win95.nt/3.1 work on win2k
I would like to install labview on my win2k box however, the only version that I currently have is 4.1 for win 95/nt/3.1. Will this version work on win2k?
I also have NI version 6.9.3 NI-DAQ software for Win 2000/nt/xp/9x. Should I install 4.1 first and then install 6.9.3. I tried to install 6.9.3 first and come up with several errors.
(2,423 Views)
LabVIEW 4.1 still works fine on Win2K. However, the latest version of NI-DAQ you can use with it is 6.6.
LabVIEW, C'est LabVIEW
(2,423 Views)
LabView 5.1.1 is the first version NI supports for Win2k. Normally you install LabView first, then NI-DAQ. When installing NI-DAQ separately you may need to specify that you want LabView support.
Here's a link that shows the reccommended NI-DAQ versions for a list of hardware.
http://www.ni.com/support/daq/versions.htm
(2,423 Views)
