wind speed program
Bill, Mike, OP that device is a 6356 !  RSE is not an option it only supports differential AI DAQmx will probably throw an error.  Connect the gnd to pin 3 an pin 5 the AI signal to pin 4 the AO to pin 16 AI and AO gnds are internally connected.
Message 11 of 16
(3,282 Views)
That's cool. The OP suggested that the wire runs were going to be long, so the measurements should be differential. I don't know what signal levels are that he's working with, but long wires and RSE spell trouble.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 16
(3,271 Views)
That's good to know.  I didn't look at any details on the 6356.  I would've assumed all DAQ devices had a single ended mode, and since that is how it appeared to be wired.
Message 13 of 16
(3,257 Views)
Once I saw AI1- not AI9 on the label I thought I'd better check the spec. Smiley Wink
Message 14 of 16
(3,247 Views)
Hello. That's mean the sensor GND connect to pin 3 and 5. The sensor out will connect to pin 4. How about the sensor +v connect to?
Message 15 of 16
(3,194 Views)
That connection is fine as is
Message 16 of 16
(3,173 Views)
