window.cpp 1232 on Panasonic Toughbook CF29
I have a Toughbook and keep getting the error "window.cpp" line 1232
Here's the confusing part:
I installed the software on an exact unit with the same Win XP image and it worked?!?
What i'm thinking is the installation is corrupted. However, i'm not sure how to uninstall the software correctly so that  i can perfomr a new clean installation .
(3,040 Views)
:bump:
(3,020 Views)
Hi qryptiq,
What are you doing in LabVIEW when you receive the .cpp error?  What version of LabVIEW are you running?  The next time you run into this, you can select to "Investigate this error" and an error log will be sent for us to investigate this issue further.
(3,007 Views)
Running LabView 6.0
I have installed a RiiD software which includes Identiview and LabView 6.0. This software is for a radiation detection device that connects to the pc.
I installed the software on another exact platform pc (hardware, OS, etc) and works fine.
(2,990 Views)
Hi qryptiq,
Have you tried reinstalling the Run-Time Engine?  You can find version 6.0.2 here.  If you are unsure which version of the RTE you have, you can expand the Software group in Measurement & Automation Explorer to find out.
(2,982 Views)
