windows 2000 sendfax bug
When accessing comm1 through labview under windows 2000 os, a send fax wizard keeps popping up. When i create an .exe the program will not even work.
(2,602 Views)
It sounds like your COM port has been configured and linked to your faxing application. I am running Win 2000 also, and don't have this problem, so I'm guessing it's just a configuration issue that you should be able to change. I would check the Wizard itself and see if you can change this configuration and if not, you'll need to look into the Windows configuration for the COM ports (yuck!).
J.R. Allen
(2,602 Views)
