windows cannot find file
Hi Jimmy,
Since the problem manifests itself only on one machine but not on others, please make sure that there are no programs/services running in the background that might make LabVIEW slower. Also try copying the block diagram of the subVI into the main VI and see if that solves it.
Ankita
Message 11 of 12
(720 Views)
Hi Ankita,
Thank you for your information. The probelm was solved. Yes, you are right. I installed the many appication programs so that the computer run a program too slower.  Now I deleted many unused programs, and then can open the labview VI normal.
regards,
Jimmy
Message 12 of 12
(710 Views)
