windows media player black when called
I'm trying to display a simple splash screen using windows media player.
I can run a wml video no problem in the attached vi but when I try to call it, (Show front panel when called), I only see a black screen, (the video doe not show).
Does anyone know what I have done wrong?
Rgds,
Seán
(4,598 Views)
Hi SeanJ,
attached a working version.
best regards
Alexander
(4,506 Views)
Hi Duffy,
Thanks for the feedback, it worked first go but then failed to work following that.
I still get  a black screen when it is called.
Rgds,
Seán
(4,504 Views)
Hello SeanJ,
how do you call the vi as a subvi in another or with the vi server functions. In my tests i used th vi as a subvi in another. Have you tried different videos?
best regards
Alexander
(4,488 Views)
Accepted by topic author SeanJ
Hello SeanJ,
my caller vi
best regards
Alexander
(4,466 Views)
Many thanks Duffy, any idea why call by reference works and not calling a subvi?
Rgds,
Seán
(4,420 Views)
Alexander,
This works great...the first time.  The issue I am having is trying to run this video again.  The screen stays black.  The Active X window needs to be reloaded to a brand new reference each time. (MP4 Video)
Any thoughts?
Andrew
(3,969 Views)
