windows media player resolution problem
hi , im using the labview 2010
newbie here .
i have a small question regarding the windows media player
i've set the size of the player to a fix size at the design phase
but after i run the project , the size of the WINDOWS media player turns bigger or smaller .
how can i have a fix size of windows media player? 😞
i nid help seriously
(5,594 Views)
Hi LOL,
Try this. Set "Stretch to fit" and "Full screen" properties of window media player to false.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(5,578 Views)
see attached file
Gaurav k
CLD Certified !!!!!
(5,576 Views)
That won't do it.  The issue is that WMP resizes to fit the default size of the media being played.  This means that each media that is loaded will automatically resize WMP.
(5,515 Views)
Have you found a solution?
(5,311 Views)
