windows prompting send error report or dont send
when am using labview application windows prompting send error report or dont send can some one help in this..I did all re installation and windows update but no use..
(2,933 Views)
You will need to provide more details as we cannot see your computer screen. Does this happen every time you launch LabVIEW? What version of LabVIEW are you using? What version of Windows? Does LabVIEW crash? If so, what were you doing at the time it crashed?
(2,924 Views)
Thanks for your reply..
The system is running with labview 7.1. The error is not coming when i launch labview. Typically its prompting once in 10 min.
(2,904 Views)
When you are using LabVIEW 7.1, what are the Windows version you are run this on ?
(2,896 Views)
Windows XP service pack 2
(2,894 Views)
