windows xp embedded network tcp/ip problem
We are running a TCP/IP connection using Labview under windows XP. Periodically, under windows XP, our server crashes. We do not seem to have this problem under windows 2000. The server code is based on the Labview examples and writes the data it two blocks - an int specifying the size of the message and the message itself. I've seen a few posts where there has been a "not enough memory" error that seems to be induced if the message is sent with two writes rather than one. I don't think this is our problem as it works under 2000 but I haven't seen any similar posts. Any suggestions would be appreciated.
(3,072 Views)
What do you mean exactly when you say the server crashes? LV shutsdown? Blue-Screen-Of-Death? XP locks-up and stops responding?
Have you watched the memory allocation for LV while your server is running? A problem in some NI examples is that they sometimes aren't as rigorous about closing open references as they perhaps should be...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,072 Views)
