windows xp serial device detected as mouse
Does anybody a solution for when a serial device conected to the PC is detected for the OS WXP as a serial mouse?
I try adding the NoSerialMiceX instruction in boot.ini but it doesn´t work and when I connect more than 7 GPS the mouse pointer get crazy.
I know that this is no a problem directly from NI but someone maybe the same problem and find out a solution.
thanks
(4,451 Views)
Oh man, I have had the exact problem with an old serial GPS device connected through a USB to RS232 adaptor.
I think I went into the Control Panel-->System---->Device Manager and disabled the "serial mouse" that showed up.
Try that first and I will check and make sure when I get home as I do not have my laptop and GPS with me today.
Message Edited by RTSLVU on 02-05-2009 07:51 AM
Message Edited by RTSLVU on 02-05-2009 07:52 AM
=== Engineer Ambiguously ===
(4,445 Views)
NoSerialMice Syntax
/NoSerialMice - Disables the detection of serial mice on all COM ports.
/NoSerialMice:COMx - Disables the detection of serial mice on COM x, where x is the number of the port.
/NoSerialMice:COMx,y,z - Disables the detection of serial mice on COM x, y and z.
ou can prevent the auto detection and installation of any Pnp-devicesby removing or renaming the newdev.dll works on XP embedded I have not tested it in XP. But XP embedded is XP most of the time
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(4,429 Views)
ok,
I´ll try that solutions.
thanks
(4,378 Views)
