winsock2 server application
I'n new on WinSock technology. I need to develop an application that acts as a WinSock server. I have example code in C to develop this server, but I would like to know how to implement it in LabVIEW. Have I got to call all winsock2.dll functions, or is there any simplier way?
Thanks for all.
Esther
(4,705 Views)
To call functions of a DLL in Labview is very easy.
What problem do you have to make this?
Umberto.
"Esther.Lopez" escribió en el mensaje
news:506500000008000000CAF10000-1079395200000@exchange.ni.com...
> way?
> Thanks for all.
> Esther
(4,705 Views)
I have never used a function call. I have to use the call library function node, I supose. There is no problem, but perhaps there were a simplier way to use winsokets, as happens with another functionalities in labview (for example the TCP/IP funcions)
Esther
(4,705 Views)
You should be able to create a server using just the built-in TCP/IP functions. There are a couple of shipping examples of TCP/IP servers and the clients don't care whether the program that's serving the data is LabVIEW, VB, or C++. On a windows platform, the LabVIEW TCP/IP functions do make a call into the winsock dll so use whatever you're comfortable with.
(4,705 Views)
Do you mean that I don't need to create the server following the process in MSDN web page (Initialize WSA, Create a socket, Bind the socket, Listen on the socket, Accept a connection, Send and receive data and Disconnect)? I just can use the TCP/IP funtions?
Or I have to follow this procedure, but using TCP/IP functions in some cases?
Sorry for so much questions!!
(4,705 Views)
You can just use TCP Open Connection, TCP Listen, TCP Write, TCP Read, etc.
(4,705 Views)
