winspec several frames
Hi all,
I'm trying to drive Winspec32 through LabView, based on the VIs given in this forum.
I wan't to be able to do N spectra very fast, and change some other parameter (without relation to winspec) between each spectrum, but :
A) If I tell winspec to take N spectra, I don't know how to make it wait for a change in my other parameter without passing by external trigger. Is there a way to drive the trigger with labview ?
B) If I tell winspec to do N times 1 spectrum, it takes at least 300ms to get this spectrum (Due to the "exp is running ?" loop). It's a waist of time I can't afford...
The files I attach to this message are for this option.
Any suggestion would be greatly appreciated !
Message 1 of 1
(2,806 Views)
