wire conflict when connecting a control to a property node (value, write)
Do not know how to solve this problem. The control (VISA resourse name) is connecting the 'VISA Open' (Spectrometer) and the property node is created from the control and changed into Write mode. Then I try to add a control to the node and a 'class conflict' error (broken wire) occurs. See attached image. Thanks in advance.
Message 1 of 10
(4,292 Views)
What are you actually trying to achieve with all this?
Message 2 of 10
(4,286 Views)
Post your code, not pictures of your code.  I'm guessing the selected class type of the controls don't match and one can be made less specific to make it work.
Message 3 of 10
(4,283 Views)
Here is the code. Could everyone see the code? Thanks.
Message 4 of 10
(4,267 Views)
I am thinking to use the property node in another page of a Tab Control to choose a usb port for my spectrometer. Thanks for the discussion.
Message 5 of 10
(4,259 Views)
So are you trying to assign a new resource to an already existing resource? A tab control is a front panel object, while a property node resides on the diagram. So what's the connection? (Sorry, posting by phone, cannot see your VI).
Message 6 of 10
(4,236 Views)
That is a bit weird.  So I created a property node Value on the control then created a control from the value terminal and the result was a broken wire as you mentioned.  The selected class of both the original control, and the one being wired to the property node were of the USB Raw type so I'd expect it to work.   The error does claim a class conflict.
Spoiler
You have connected a refnum of one type to a refnum of another type and both types are members of some class hierarchy, but there is neither a simple up cast nor type cast between the two classes.
Changing the control wired to the property node to a class type of Instr removes the wiring class error.
Edit: It gets weirder when local variables are attempted.
Message 7 of 10
(4,230 Views)
Hi Frank,
There's no TAB control in your VI nor is there any property node.
What exactly do you want to achieve?
Message 8 of 10
(4,229 Views)
Yes, it is strange. Hope I can solve it and give you a solution. Btw, how can you add 'Spoiler' section?
(If we change the type to Instr then the wire between the control and the spectrometer break. )
Message 9 of 10
(4,211 Views)
Instead of insisting on this convoluted thing with property nodes, stick to established coding practices and solve it without property nodes and good code architecture instead. I am sure there is a way!
And please attach relevant code. Whatever you have attached has very little to do with the problem you are describing.
To add a spoiler tag, use the 5th item in the edit bar (it even tells you when hovering over it).
Message 10 of 10
(4,204 Views)
