wire name
I have a problem using the "unbundle by namne" function. I guess it is because my data in the cluster in the array don't have names. I have 8 channels, but at the wire they all have same sames. How do I name the wires?
Thank you for the help!
(2,847 Views)
hi,
you can name them by naming the indicaters used to build the cluster or to name the indicators in the origin cluster on the frontpanel.
B. Bakels
Labview CLD , Engineer/Manager
Promedes and DSM
using LV 7.1, 8.0, 8.2, 8.5 and 2009 SP1
http://www.promedes.nl
(2,845 Views)
