wireless communication
hi,
I'm assembling a system which will read a GPS, electronic compass and 34 digital channels into a computer and then transmit the data wirelessly to another computer. I'd like to control the whole thing with LabVIEW.
I thought of using either Wi-Fi or RF for the communication. RF products seem to be somewhat cheaper, although I'm not sure if they are as simple to use as a Wi-Fi router for example. Does anyone have any suggestions about communication systems that would be easy to use, cheap and work with LabVIEW?
thanks,
Jon.
(2,834 Views)
Hi Jon,
I have found some resources that may interest you.  In regards to WIFI with LabVIEW, here is an atricle that talks about how to integrate WIFI with NI products.  I have also found some good tutorials on how to do RF design and basic measurement fundamentals here and here.
I hope this helps,
Nadim
Applications Engineering
(2,790 Views)
