wireless connection
Hello Forum.
I am using the following equipment from National Instruments:
NI WLS 9163
NI 9219
I set 9163 as the NI WLS wireless system through an ad hoc network.
I and acquiring the values ​​of resistance (voltage with custom Excitation) of load cells wired in full bridge.
Everything works!
However, the acquisition rates are very low!
I can not get acquisitions with more than 2 Hz (high resolution)!
Will can help me on the following issues:
This is because the equipment I am using?
How can I change that with this equipment?
There is another wireless system from NI, with better results for this application?
I appreciate the help! :smileyhappy:
(Not sure if this is the most suitable place, if not ask for it let me know)
(4,341 Views)
I've not worked with the 9163 not the 9219, but I doubt 2 Hz is the fastest data rate.
Perhaps the problem is with configuration, or your acquiring code. Can you tell us more about your setup configuration, and perhaps provide us with your code?
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(4,317 Views)
Dear Thoric,
Thank you for your answer. I saw that this was not the right place for this message. You can visit:
http://forums.ni.com/t5/Multifunction-DAQ/Wireless-System-WLS-9163/mp/2101306 # M72264
Have added some prints.
Thank you!
(4,299 Views)
Hello again,
Allow me to correct your link : Wireless System (WLS 9163)
Jérémy C.
NI France
(4,294 Views)
I've replied, over in the other thread... Smiley Happy
(4,291 Views)
